Panasonic PV-GS2 Mini DV Digital Camcorder Logo
Anonymous Posted on Nov 15, 2006
Push the reset button
Sometimes my Panasonic Mini DV will suddenly say Push the reset button, but as many times as I do this it keeps repeating that. I used to be able to take out the battery and it would work again but nothing works anymore. PLEASE POST ANY TIPS!!
tusamgdesam
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Feb 04, 2009
tusamgdesam
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
14394
Points
34
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
A
Anonymous
My camera has been doing this too, searched this site not through product but problem and found this solution posted by "margarita" for another camera. Said to try removing/replacing the tape. When I pushed the eject button the tape did not come up, removed the battery for a minute and tried again. This time the tape came up so I removed it and put it back in, it seems to have worked. The reset button is not flashing and it did record and playback when I tried them.
2 Related Answers
Anonymous
  • Posted on Jan 12, 2008
SOURCE: Push the reset button
Dude, I have the same problem.Whenever I am getting ready to film, and I also have a Panasonic MiniDV camcorder, it will Say PRESS THE RESET BUTTON. I also have the same problem about the cassette holder, for it won't open. I don't know what the hell is going on with it. I have a model PV-GS9.
Anonymous
  • 5 Answers
  • Posted on Mar 13, 2009
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
My panasonic pv-gs9 keeps telling me to "push the
Push the - what ? We are all agog to know what you have to push, provided the answer is suitable for family viewing.
2answers
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
2helpful
2answers
When i rewind it comes up with press the reset button
Solution:
cassette housing
Hope this can help.
1helpful
ReSET BUTTON
The same happens from time to time with my panasonic NV-GS11 GC video camera and I have no idea what is causing it. But what I normally do is just turn it of wait 10 seconds and turn it on again. If it stil comes on try removing the tape and see if it is faulty.
3helpful
3answers
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
1helpful
3answers
Panasonic Mini DV NV-GS11EG "push the reset button"
i know what to do next brother go to field or a soccer field and trow the bloddy thing away
11helpful
3answers
Solution:
cassette housing
Hope this can help.
4helpful
3answers
Push the reset button,PANASONIC NV-GS11
My NV-GS15 asks me to push the reset button every time I turn it on
Panasonic Mini DV Camcorder
Take the tape out to keep it safe, then remove the battery for 24 hours.
2answers
Panasonic PV-GS31 won't FOCUS
Just a hunch as sometimes the micro will get scrambled so take off the battery as well as the battery or batterys for the date and time. and let the unit sit for 24 hours power back up as see if that cleared your error If not send away to get repaired.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
