Televison & Video Logo
Anonymous Posted on Apr 14, 2012
Pls give me a circuit diagram of panasonic tv model tc-29sf3
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Apr 15, 2012
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987150
Points
237762
Send your email address to me. I'll try send a copy of the diagram to you by return mail
  • 7 more comments
  • Anonymous Apr 15, 2012
    [email protected] thanks waiting for ur reply hope it will help thanks again
  • The Knight
    The Knight Apr 16, 2012
    I've snd the service manual to you a few while ago.
    Gopakumar G, South India.
  • Aihrene Degamon
    Aihrene Degamon Oct 11, 2013
    hello can u send it to me also? my husband badly needed it.. thanks much.. [email protected]
  • joey birad
    joey birad Mar 29, 2014
    hello dn po, pls send it to me also, missing po ung 2 resistors at 1 zener diode.
  • joey birad
    helo po pls send me panasonic diagram tc-29sf3..thanks much
  • rejun villacruz
    rejun villacruz Jun 25, 2014
    please send me power supply diagram of tc-29sf3.thanks a lot..
  • archie tamara
    archie tamara Feb 05, 2017
    kiahalhe bai....please send me also the schematic of this model,am having problem in the power supply section....thank [email protected]
  • jerronh meraballes plata
    please send me a diagram supply of TC-29SF3 thanks.
    parts of panasonic TC-29SF3
5 Related Answers
Anonymous
  • Posted on Jan 14, 2009
SOURCE: TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
UberTechzor
Daniel
  • 299 Answers
  • Posted on Sep 11, 2011
SOURCE: Dear Sir,will you be pls
Hello wilson_deniz,
Welcome, and thank you for using FixYa!
The maunals you seek can be found at the link I have included below. But you will have to locate your Model Number on the back of the TV. The manuals also cose $4.99 each.
Sansui Manual
http://www.sansui.owner-manuals.com/SANSUI-manuals-6-20a.html
Small price to pay if it helps you fix the TV.
Have a great day!
darjr
Darial Jr Lasaria
  • 379 Answers
  • Posted on Sep 10, 2009
SOURCE: Hi, I have a panasonic tv model tc21xy3 standby
Your Tv Horizontal deflection doesn't work, try to switch ON your TV by remote control or by pressing the program up or down button in the TV set. If still working check the B+ in the capacitor rated 200Vdc. monitor the voltage as you press the program button, it must have a 90vdc , or remove first the Horizontal Output Transistor before you switch on the Tv. Then monitor the Voltage in B+. If it is present your Power supply is good, if not then check the component in Power supply section. if the B+ is present check the horizontal area.
Anonymous
  • 1274 Answers
  • Posted on Mar 20, 2010
SOURCE: circut diagram of panasonic Tv Model
Get it at MatEletronics.com ..hope this helps..
Anonymous
  • Posted on Sep 17, 2010
not video
Pls give me a diagram of panasonic TC-29SF3
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Circuit diagrams of many popular brand TVs and other devices are given.
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Circuit diagram of power supply model tc-29sf3
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
21 circuit diagram panasonic tc
Circuit diagrams are in PDF, and cannot upload by this window. If you wish to some details, check the site linked here. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
6helpful
3answers
Panasonic Sophia Model TC-2130TD : no DC
PANASONIC TC-2130 MAI PROBLEM YAI A RAHE HAI KAI TV ON KARNE PER VIDEO KUTCH DAIR SAHE ATE HAI 5 SAI 10 MINT BAD VIDEO ASEE HOTE HAI JASEE ABL MAI NAGATIVE PIC HOTE HAI LAIKN YAI CONTINUE NAHE HOTA KABHE NAGATIVE HOTE HAI KABHE SAHPNESS YA WHITNESS BARH JATE HAI COLOUR BAHE PHATE PHTE SAI ATE HAIN ABL KEE RESETANCE HALKI SEE HEAT HOI HAI VALUE METER PER 180 K BATA RAHE HAI KAYA MASLA HO SAKTA HAI PLEASE TOTAL GAIDE ME
2helpful
2answers
Circuit diagram of grundig 5441 tv
Dear Sir,
According to your request i am providing download link
Circuit diagram for Grundig 5441 tv. If you have any problem regarding this issue come back with more information about the problem,we will glad to assist you
Preview
in PDF format download High resolution complete Circuit Diagram
Download Circuit Diagram
Thank you for choosing fixya
Good Luck
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
