Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
Joy Muir Posted on Sep 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Maytag Bottom Freezer French Door Refrigerator. The freezer is developing ice on the bottom and then water leaking out onto the floor. Also frost is building up inside the freezer. The setting on the freezer was set at 4. Have now cleaned out the ice. Is there a different setting that I should put on the freezer? Or anything else to prevent this from happening?
Bob Jepsen
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Sep 02, 2017
Bob Jepsen
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
6676
Points
40
Maybe this will help, look up my answer. I went into detail what was wrong with my french door bottom freezer. My refrigerator never had a similar problem again after this. Good luck
Chris Huff
Level 3:
Top Expert:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Maytag Master 6,289 Answers
Chris Huff
Maytag Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018770
Points
74913
Frost build up is caused when unit is not defrosting. One or more of your defrost components are probably bad...defrost heater or defrost thermostat or defrost timer / board. Water leak is probably a defrost drain stopped up
paul gallagher
Level 1:
New Friend:
  • Contributor 14 Answers
paul gallagher
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
5553
Points
38
Either a leaky door seal blocked drain in the freezer or burnt out defrost heater element
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Oct 02, 2008
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Anonymous
  • Posted on Feb 18, 2008
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Mar 27, 2010
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Anonymous
  • 72 Answers
  • Posted on Jun 11, 2009
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Michael Koronka
  • 9 Answers
  • Posted on Jun 14, 2009
SOURCE: Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
1helpful
Water leaking onto the floor of the freezer covering the bottom with ice. Every few days we have to crack the ice and get rid of it .
the drain tube hole behind the inner rear panel in the freezer has plugged up and when it defrosts the water cant drain down to the condensate pan at the lower rear of the unit to evaporate
Maytag mff2258vew2 french door bottom freezer leaks
The cabinet heater in freezer is may not be working and causing condensation on the walls of the freezer. Have it checked by a service man.. also make sure the refrigerator is level. and it is not over packed with food. Newer models must have a certain amount of space for the air to circulate.
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
2helpful
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
5helpful
2answers
Water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
Ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
