The only option go online to Samsung and contact customer support and technical department to see if one is available, also check www.ebay.com Type: make and model refine research to remote.
SOURCE: blu ray disk wont play.
this could be a failure in the processing secttion of the card. since this is only months old it is important that you take this for warranty claims and get the immediate attention. It could be also expensive if it is out of warranty, possible failure of the proccs board.
SOURCE: LG BD 300 blue ray player won't play dvds
have you tried more than one dvd ?? i have heard that even the slightest mark on a disc and they won't play hope this helps regards Jim
SOURCE: blue ray quit recognizing non BR disc
The non-blu-ray laser lens needs cleaning.
Try not to use a blast of compressed air.
Radio Shack has a lens cleaner ($13). it is an audio CD with a row of brushes on it.
Read & follow the directions.
SOURCE: Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
SOURCE: Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
