The electric supply went off in the house for two days and when it came back on i had to press the orange button to start the chest freezer again. since then the orange standby light has remained on. Should this be happening?
SOURCE: my whirlpool 11-3 chest freezer is starting to
is the compressor running if not check the defrost timer
SOURCE: we got a philips whirlpool chest freezer my
Orange switch only by passes the thermostat. It sounds like your freezer is either out of gas or the cooling fan (if there is one) is not working.
Testimonial: "ok thanks for advice"
SOURCE: RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
SOURCE: got three lights on my whirlpool super chest
This is a super freeze button, it is for when you get a lot of frozen food and put it in you can push the super freeze button and it bypasses the thermostat and runs the freezer constant to freeze the food quicker.
SOURCE: My chest freezer (10 years old) won't freeze.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
