After washing drum will be dry. After several hours when I check the drum there will be several inches of water in drum. I have to drain the drum before doing a wash.
SOURCE: completes wash cycle hits rinse cycle and water will not drain
is the pump working? It's attached to the motor.
SOURCE: Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
SOURCE: water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
SOURCE: Why is my LG washer/ front loader Model (WM2233HS)
two things could be wrong the fist check that the filter is not blocked its at the frunt bottom right near the floor right side put towls down theres still 10 cups of water in there ok pif you can twist the black or it could be white knob take it right out then check to see if its empty if it is then it sounds like you moter brushers ok i can onlt try to help ok please rate me if i have helped you
