Question about LG Televison & Video
55 inch led tv will not recognize my hdmi cable?
TV will not recognize HDMI cable. I was watching television and suddenly the screen went blank and I got a no signal message. I unplugged everything and reconnected my tv box to no avail. I still continue to get the no signal message
    New Friend:
  • 3 Answers
On you r remote there should be three hdmi settings just try each one it will likely work with one of them
Posted on Apr 16, 2012
Anonymous
SOURCE:
Anonymous
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
jose martinez
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
Anonymous
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
Anonymous
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Posted on Oct 31, 2009
Anonymous
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
TV screen is blank but the program is still playing
Check the cables, makes sure all connections are still snug. If your using HDMI, try swapping it out for one you know works. There are a lot of lemons out there.
Feb 24, 2016 | Televison & Video
Hdmi blocked blue screen
If you are using a box for signal have you unplugged it also?
Dec 22, 2012 | Philips 42PFL3704DF7 42 LCD TV
Screen goes blank while watching TV and playing DVDs
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Mar 19, 2017 | Marantz NR1602
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
Tv stopped working
Check input signal comming in, is there any?With another tv see if u have cable or free air signal.All that check,than ur backlight inverter board is dead.
Sep 09, 2009 | Spectroniq PLTV3250 32 in. LCD TV
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vizio 42" LCD HDTV - sound went out
Same thing just happened to me contacted Vizio had me unplug the TV from the wall for about a minute and then replug and cut the TV back on and everything was fine. I have the television hooked into HDMI1.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
1,094 people viewed this question
Ekse
RONALD CARTER JR
