Red light not on. No power
SOURCE: REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
SOURCE: my akai pt4299hd tv stopped working. it will not come on.
On AC power supply board there is 2 thyrisitor poor solder ,I have repair several of these with that problem.
SOURCE: My akai dlp tv is
the back cover is not on the TV correctly. on the back cover there is a safety switch so that the lamp light is not exposed. The lamp emits radiation and UV rays. Not healthy.
SOURCE: AKAI PT46DL10 NO POWER / NO PICTURE / NO LIGHTS
very likely the power supply (no fuses inside)
