My Dell A920 prints everything except envelopes very nicely. When I use the format in Microsoft Works with return address and addressee and click print everything normal happens except the printer puts NO INK on the envelope or anywhere else. It makes the printing noises and the window showing ink levels and print progress etc is up there but when the envelope comes out is it blank!!!
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
I suspect Works thinks your envelope is 8.5 x 11 or thinks your envelope is oriented in the opposite direction (long end first instead of narrow end) and is "printing" on air. Try printing the same job again except use a standard piece of paper and I'll bet you see something. I haven't used Works in years but its basically a stripped down version of Word. If you?re using the envelope printing tool there should be an options or printing orientation section. Make sure you've got the envelope orientation set correctly here.
Hi - I'm using Windows Xp with MSOffice 2000. Same issue - My Lexmark makes all the right noises and spits out the envelope with no ink on it. I tried a blank sheet of paper. Same result. No ink on paper. Any thoughts appreciated
My envelopes have printed correctly for years, however this Dec. the print is faint and green and red. If I print on paper, it prints black. What has happened to my Dell A920?
will not print envelopes through word
The envlope feeds through and it makes printing sound , but envlope comes out blank. It will print everything else.
Same here, with any envelope Dell 920 printer sounds like a duck, quacks like a duck, but when prints out envelope looks like a yellow blurred image.
