Need to remove front panel of Maytag Epic Z dryer in order to vacuum out front as dryer is not drying very well.
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
SOURCE: maytag epic z gas dryer
hi thanks for the question. i thhink your problem is with the gas valve coils located on the valve replace those cheap parts thanks the appliance doc
SOURCE: Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
SOURCE: I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
