I have tried starting the projector first, then turning on the laptop, and have tried the reverse. I've tried two serial cables (though I only have one mini dmi or whatever it is that plugs into the macbook) in both the configurations above. The error message appears only after the macbook is plugged in. Therefore it seems that there is some form of communication between the computer and the peripheral. I have an important show tomorrow. Is anyone out there?
SOURCE: "Frequency is out of range"
Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
