Screen reads" cannot read disc "on three different brand new discs
SOURCE: Cannot read disc, unable to recognize..........HELP
In order to finalize your disc the dc210 MUST be plug into an outlet!!!
SOURCE: Finalizing a disc (when plugged in) on a Canon DC210
I think it is a problem with the camera.
We had one, couldn't finalize, exchanged that, and still the same problem.
Canon NO help whatsoever.
Even the mini disc companies that we purchased, NO help either.
We are returning this camera and going with a hard drive.
We were able to plug the camera to a DVD recorder and copy onto a full size disc.
SOURCE: Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
SOURCE: Mini-DVD playback
i have the same problem.... i have finalized the dvd rw from my Canon DC310. And what i want to do, add transitions and text to my finished video. So i downloaded the trial version of SONY Vegas Movie Studio 8. But my computer wont read my disk =(
So, does it mean i need to get a new computer? lol
SOURCE: Cannot intialize/finalize mini-DVD in Canon DC210
The way to get it to finalize is like this:
1. turn it on
2. use cord.
3.move the on buttom to mode. it will show the recordings.
4. select a recording
5.press function butom. it will up bring several choices among "menu"
6. slect menu
7. it will give you all the chioces you need to title, finailize, protect and all needed to view the dvd
Any questions,
let me know.
OL
