The tire leaks air through stem valve. I need to replace tube but don't know how to get the lock ring off to remove the tire.
SOURCE: Losing Tire Pressure for left rear tire repeatedly
most likely there is a small hole or crack in the tire, and when you drive the rubber gets hot and losens up allowing the hot air inside that is expanding to escape. my recomendation is to replace the tire. better safe than sorry when it comes to tires. good luck to ya
SOURCE: Tire Leaks at Valve Stem
not just chrysler, there are many wheels from manufactures that have the same type of problems. chances are they will not help you.
SOURCE: 2006 tundera tire pressure sensors are letting tires leak air
The Toyota dealer should have replacement seals if your leak is at the base or replacement sensors if too damaged
SOURCE: Can I change the tire pressure valve stems on my
does the car have TPMS? if so they make a kit where u can replace the core of the stem that will re seal it. if it only has a standard valve stem then a tire shop should have replaced them with the set of tires, the only way to replace them is to remove the tire.
SOURCE: tire slowly losing pressure over several days
I WILL BET THERE IS A NAIL OR SCREW IN THE TREAD SOMEWHERE AND U HAVE NOT SEEN IT BECAUSE IT IS GROUND OFF FROM THE ROAD. THAT IS THE PROBLEM JUST ABOUT 99% OF THE TIME, REALLY DOUBT THE VALVE STEM IS THE PROBLEM.
