I would like to find out the size and where to order
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email [email protected]
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
SOURCE: SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
SOURCE: invicta #0564 russian diver large
Hi.
As you probably expect, replacement parts for the watch cannot be directly purchased directly from the Internet, choosing from an online part list.
You will need to submit a service case to Invicta. Here the page.
The only other option is finding a local repair shop.
Regards.
Ginko.
SOURCE: Hi i just got an
I have had the same problem with one of my SANIIIs, As you have probably figured out, there are two small screws that are part of this assembly, lower one is the pivot point, upper is the latch. There are also very small rubber bushings (upper & lower) in the pivot of the crown protector, if they are worn it will present side to side movement or "slop" they need to be replaced in this case (I Just went through this on an older Valjoux 7750 SANIII - same problem, latch would not stay closed), you can order the part from Invicta or take from a donor watch in the mean time (Invicta will take several weeks to months to fulfill a part order) The upper screw goes through a small cylinder or cam, there is a little (very little - but it is there) to move that cylinder outward towards the upper pusher or top of the watch. After you loosen the top screw (loose not remove) you can adjust this play w/two precision screwdrivers, one to tighten the upper screw one to lever the cylinder toward the top of the case by leaning one screwdriver w/ just a slight pressure against the crown and the cylinder to widen the area between the pivot screw and the latch cylinder. Don't overtighten the screws to try to add friction to the assy - the threads & heads are fragile, you can damage the case or strip them - or worse snap the head off. Hope that helps.
SOURCE: INVICTA SUBAQUA NOMA 3 SCREWS LOOSEN I have had
Ther is a glue called "loctite", which is used in engineering to avoid the problem the you are having.
Put "loctite" into your search engine to find a local supplier. There are several varieties of glue and most suppliers will be able to advise you on which one is suitable for your screws.
SOURCE: I have an Invicta subaqua
Browse through my Tips and Tricks. You will find there link to all Invicta watch manuals.
it is a screw bar 26mm in length and approximately 2mm in thickness with flat socket ends that are 4-5mm in diameter that hold the watch band to the case
looking for screws for my invicta model 6211. the screws are for the back case of the watchrs.
