Hi
If the folding mechanism has become broken it is not possible to force close the product without causing further damage.
Please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the screen to send your enquiry to the customer care team in your country who can advise of next steps to take for the chassis to be inspected/repaired.
SOURCE: We have the quinny buzz pram (about 20months now)
YOU CAN HAVE IT REPAIRED AT WWW.BUGGYPITSTOP.CO.UK
Testimonial: "Thanks will email them!!!"
SOURCE: pink quinny pram
start at the top and slide the 'cords' attached to the fabric off and away from the metal frame then do the sides and the same for the bottom, i know it is hard because you cant really see how it is attatched, but it is possible
SOURCE: Quinny Carrycot Compatible with Quinny Dreami?
The Dreami for the Freestyle 3XL is compatible with the Buzz. You will need to get a set of Buzz adapters (these are the same adapters that you would use to attach the Cabrio Fix carseat) these should cost around £18 or see if you can get them on eBay!
Hope this helps.
SOURCE: Hi, I have a Quinny Buzz pram that has an
HI,
This sounds like you need a replacement gas cylinder. This is not something that you can do yourself and would need to be undertaken by a qualified person. You need to contact either your retailier or www.dorel.co.uk
I hope this helps.
