many components can work when cool but after heating up lose conductivity, could be many different components that might cause this, needs a professional to track it down
It should be replaced with a new one. Normally these type of faults are irreparable.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen faults & possible causes to LCD screen are given with illustrations.
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Hi! It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
