The water pump in a Bissell CrossWave is a vital component that is responsible for pumping water from the tank and through the cleaning brushes. If the water pump is not functioning properly, it can cause the CrossWave to perform poorly or not work at all. Here is a breakdown of the parts that make up the water pump in a Bissell CrossWave:
Motor: The motor is responsible for driving the pump and is typically a small, electric motor.
Impeller: The impeller is a small, rotating blade that is attached to the motor shaft. It helps to move water through the pump by creating a suction effect.
Housing: The housing is a container that encloses the motor and impeller. It is typically made of plastic and is sealed to prevent water from leaking out.
Inlet and outlet ports: The inlet and outlet ports are openings in the housing through which water enters and exits the pump.
Seals: Seals are used to prevent water from leaking out of the pump and are typically made of rubber or a similar material.
Gasket: The gasket is a flat, circular piece of material that is used to seal the housing to the body of the CrossWave.
If any of these parts are damaged or not functioning properly, it can cause the water pump to break down and may require repair or replacement. I recommend contacting Bissell or a professional repair service for assistance if you are experiencing issues with the water pump on your CrossWave.
1. Tanks may not be seated properly.
2. If it has a portable spot cleaner, then it may not be attached properly.
3. usually on vacuums, there is a suction gate...it may be open and not closed..
When the vacuum is not picking up stuff like that it is a good indication usually that the belt is worn, stretched or broken. You can get the belts for this model and view the manual here:
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
