It sounds like a noise in a wheel
I would make sure it is snapped in to place. Does it appear that the fan is balanced? If it wobbles the slightest bit, the fan blades are not balanced and therefore needs to be replaced. I would consider returning the unit, they are supposed to be whisper quiet.
Spray lubricant onto the fan shaft as close to the fan body as you can. it will work it's way into the bearing
This will not work. the squeak is on the opposite side and it's a sealed bearing
