SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
SOURCE: no picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I called Sony repair and they said to bring my set in for evaluation. They think it is just the back light. Maybe $300 - $400 to fix. If it is the panel I will scream!
SOURCE: 13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
SOURCE: 13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
