Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen. In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
When you replace the CMOS battery, you must wait about 10 minutes with the old battery removed, before fitting the new one (if you had a problem with the error message before) - when you fit the new battery, plug the tablet in and don't turn it on - this will give the new battery a chance to power up all of the CMOS on the board and settle down. Then turn it on, wait for the error message about the date and time being wrong, set the time correctly and the problem has gone.
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.: BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
The GPU graphics chip fails a lot in this model. It usually means a motherboard replacement. I've had it fixed 4 times at a cost of $600 each time at a authorized repair center but it reoccurs a year after. The GPU fan doesn't come on enough to cool the graphics chip so it fires or gets unseated.
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
