I have had this television for almost 5 months. just last night the tv wouldn't go past the start screen (when you turn it on it says vizio then usually goes to the channel i last had it on) Ive tried unplugging it, waiting a few minutes before trying to turn it on again. ive done this several times and even left it unplugged all night. What can I do to fix this problem?
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
SOURCE: My Vizio TV Screen went black last night. I cannot
The slave inverter problably went out. Good luck finding if it is a 6632L-0471A The same thing happened to me and I can not find one.
I forgot to add that the remote and the buttons on the tv wont work to turn the tv off. the only thing connected to the tv is a vizio blu ray player that i got at the same time.
