How to program a viper 7142V remote
SOURCE: how do is program a viper alarm and remote starer
first you will need to locate your valet switch/button, which will be a black push button located somewhere under the driver side dash.
Open a Door,
Turn your key to ON position,
within 5 seconds of turning your key to the ON spot,
press and release the program button 1 time, then press it a 2nd time and hold it this time
the L.E.D will flash one time and then you will hear a chirp,
while still holding the valet switch, press the lock button on your new remote. you should hear a single chirp.
After chirp you can release the program button and turn the key to off.
you should hear a long chirp when the alarm exits the programming
try the remote
if the remote functions don't work properly, you can always try a different # pattern.
ex: press 2 times and hold on the 3rd, press 3 times and hold on the 4th.
SOURCE: 2003 chevy trailblazer. alarm problem 771xv
CHECK THAT YOUR BYPASS POWER IS ONNECTED TO THE ACC.CABLE FOR IT WILL NOT DRAIN YOUR BATTERY
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
