Question about Kyocera Mita Office Equipment & Supplies
Kyocera FS4020 - how do I get it out of envelope mode
Printer message - says its in envelope mode. We have changed the toner and removed a paper jam beyond the green lever over the cassette. Now its in envelope mode - how can we get it out?
  • 7,733 Answers
When you start print there is a option to change it,i guess is like "properties" hit it and change the configuration.
Posted on Apr 19, 2012
6ya staff
SOURCE:
Anonymous
  • 50 Answers
SOURCE: how to remove toner drum on the Brother MFC-7840W
http://www.brother-usa.com/manuals/default.aspx?ProductID=MFC7420&ProductGroupID=5&WT.cg_n=Support&WT.cg_s=Manuals
Go to that link and download user manual or read their support pages
Posted on Mar 20, 2009
Anonymous
  • 3 Answers
SOURCE: Paper Jam Message
Thanks for the solution. I have a oki B4300, same problem.
I opened top, removed toner/drum. On your left, in front, there is metal roller held by springs. Plastic strip is just in front of this. Two square windows under plastic strip should look dark.
In my case, the Left "window "was white. This was a very small piece of paper which also extended under a small, moveable magnetic switch to the far left. I removed this paper by grabbing it (next to the switch) with a pair of surgical forceps, gently twisting it until it could be pulled out. No need to remove any parts. It now is fixed!
Thanks again.
Posted on Feb 27, 2008
Anonymous
  • 15 Answers
SOURCE: DCP 7020 Brothers laser printer paper jam & back cover open fault
Try doing the following prior to messing around with the fuser itself:
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002000/000024/faq002024_006.html?reg=us&c=us_ot&lang=en&prod=mfc7820n_all&Cat=4
Posted on Jun 13, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
Anonymous
  • 4 Answers
SOURCE: paper jam and toner message - no paper jam and new toner
Had the same problem Look into www.fixyourownorinter.com
Took the Formatter card out, BAKE for 8 minutes at 350F, let it cool, put it back in and VOILA! Put the card fase up and make sure (with screws) it does not touch the pan you used to bake it.
Good luck
Posted on Oct 27, 2009
Kyocera 2100dn says paper jam in duplex unit but there is no jam paper.how can i fix?
the duplex unit is on top of paper cassette remove the cassette pull down the green lever inside the machine and remove the paper jam you cant see the paper otherwise
Feb 08, 2017 | Kyocera FS-2100DN Laser Printer - FS2100DN
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Paper jam in HP 1200 printer
Hi,Make sure you got every single piece in there, and if you can't get it to work, just hard reset it. Unplug it from the wall wait 5 seconds, plug it back in. Should be good as new.
The LaserJet 1200 has two paper inputs, a regular paper tray and a priority input tray that is used for envelopes, labels and transparencies.
Paper jams rarely happen with the HP LaserJet 1200. If you can see paper sticking out of the input or output tray, try to remove it gently. If you encounter resistance or if the page tears, turn off the lights in the room to avoid exposing the toner to light. Open the toner door, which is above the paper tray, and the output door, and rotate the green levers down. At this point, you might be able to remove the jammed paper. If not, remove the toner cartridge.
Grasp the page in both hands and gently pull it free. Replace the toner cartridge and close the doors. The cartridge and the levers will slide back into place.
Hope that helps..
Mar 15, 2011 | HP LaserJet 1200 Printer
Toner cartridge doesn't fit. I removed it to clear paperjam. Now it won't slide in completely. What do I do?
What probably happened is that when you removed the paper jam, some piece of the printer became unaligned. This piece is blocking the path to put the toner cart back in. In most HPs there levers inside the printer that are green, and that indicates that they are paper jam problem areas. You can move the green lever to open up a place where you may see paper stuck. Make sure all these green lever items are in the correct position.
Sometimes the toner carts are just a little tricky to put in. So if you haven't done it before, just ensure you are doing it correctly. I've also had people try to put it in upside down. I doubt that either of these are your problem, though.
Whatever you do, don't try to force the cartridge back in.
Jul 16, 2009 | HP LaserJet 2100 Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Prints dry colour powder on paper
You aren't fusing (melting) the toner to the paper. The probable cause for this is having the "envelope feed" levers in the "envelope", or up, position. This leaves a wider path for the paper, which does not allow the toner to be fused onto the paper properly.
The envelope feed levers are the two small green levers at the rear of the printer, one on each side, that are visible when the printer's top is lifted.
Dec 16, 2008 | Xerox Phaser 6120/YN Laser Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Ink
On the fuser (under the top cover), there are 2 green levers with envelopes on them. The one on the right is probably flipped up. The purpose of these levers is to decrease pressure on the paper when printing on envelopes which are 2 or 3 layers of paper. It reduces the wrinkling that occurs when printing envelopes on most laser printers. Flip that lever down and you're golden.
Nov 04, 2008 | Xerox Phaser 6120/YN Laser Printer
Recurring error
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Nov 16, 2007 | HP LaserJet 3330 All-In-One Printer
8,989 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
