Symbol MC3090 Logo
Posted on Apr 18, 2012
How to disable "close battery door" on the mc3090
Hello everyone, my MC3090 is with the broken latch batteria. how to disable the "close battery door" to start normally? thank you now.
Waseem Akhtar
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 20, 2019
Waseem Akhtar
Contributor
Level 1:
Answers
Questions
0
Helped
1917
Points
It is very easy, there is a little button which need to press which tells the scanner that battery door is open. carefully check the battery door sides there will be extra embossed pin with normal battery door which press the button when we close the battery door. when this inner side of battery door gone damage which press the button.
Waseem Akhtar Tanoli [email protected]
Anonymous
Level 1:
New Friend:
  • Posted on Oct 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1917
Points
The clip on your battery door is broken, order a new door this is the only way to fix the error
3 Related Answers
Anonymous
  • 5 Answers
  • Posted on Sep 10, 2009
SOURCE: (WINDOWS XP) computer can't find driver for connecting to mc3090
I've got your answer!
Free troubleshoot, contact Lexicon Technologies.
Call: 1-800-678-1744
Email: [email protected]
Web: www.lexicontech.com
Anonymous
  • Posted on Nov 14, 2008
SOURCE: cradle and cable part numbers to charge a Symbol MC3090
u buy cradle for mc3090 .... it is so simple... u r boss may getting mess up with you
Anonymous
  • 58 Answers
  • Posted on Nov 10, 2011
SOURCE: Dear all I need help
you need to re-flash to O/S. If this fails then you have a main board/CPU Failure. If you need assistance with this please contact [email protected]
Factory reset on mc3090
I am assuming you meant Motorolla MC3090 mobile comupter running Windows CE.
MC3000 User Guide - Motorola MC3090G Win CE 5 0 Core User Manual
On 28, 38 and 48-key keypad configurations, press the Power button to turn on the mobile computer. On 20-key
keypad configurations, simultaneously press the Fn and MENU buttons to turn on the mobile computer. If the
mobile computer does not power on, perform a cold boot. See Resetting the Mobile Computer on page 2-28.
When the mobile computer is powered on for the first time, it initializes. The Splash screen appears for a short
period of time, followed by the Calibration screen
Couldn't get PM power status error shows while booting in MC3090-G.
I figured out, that the problem i caused by badly connected motherboard cable. I solved it by assembling the "display etc" part with the motherboard firts, then connecting the MB cable firmly, and finally put together with the "gun holder/battery closet" and secure it with screws
Where i can found charger for motorola mc3090
Go on ebay put in MC3090 and scroll through results till you find a charger. Should be quite cheap to.
1helpful
I want to bring a Symbol MC3090 into WIFI
You can accomplish this by using Fusion utility on your MC3090 I can provide steps necessary for this request. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
2answers
MC3090 is having trouble scanning 2D labels. It
No...check the printer that is creating the 2D code. It's probably the culprit. Make sure the head is perfect and the 2D code is big enough. The 2D version of the MC3090 doesn't read small 2D codes.
If it still doesn't work, contact your dealer or the Moto Help Desk at 1-800-653-5350
Why my MC3090 Scanner doesn'n scan when i open Microsoft Wordpad?
You would need to install and run an scanning application. On the suppor.symbol.com webpage is the application Datawedge available.
2helpful
1helpful
Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
23helpful
2answers
How can i cold boot my symbol device mc3090?
press and hold 1 & 9 ,then press power.
Cradle and cable part numbers to charge a Symbol MC3090
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
