Question about Kenmore 24032\24036 Top Load Washer
Washing machine will not spin
After the wash cycle is done, it will not go into spin cycle, thus not draining Kenmore Top Load Washing Machine
Model 20852 990
Will not spin
  • 3 more comments
  • sweder Nov 14, 2008
    Find the back cover of the washing machine too hard to remove to see if it is a belt problem. Does not seem to be an electrical problem as the washer goes through the "wash" cycle.
    Can hear the motor trying hard to spin but it will not.
  • Anonymous Nov 15, 2008
    SOME TIMES IT WILL SPIN OUT OTHER TIMES IT WON'T
  • Anonymous Mar 13, 2014
    Front Load Washing machine not draining and or not spinning heatman101
  • Anonymous Mar 18, 2014
    can wash anything machine flashes c1 when cycle is working
  • Anonymous Mar 24, 2014
    Washing machine won't drain on 2nd cycle
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
6ya staff
SOURCE:
Washer not spinning on spin cycle..model#16502690
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Aug 10, 2011 | Kenmore Washing Machines
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Kenmore Washing Machines
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
heatman101
Feb 19, 2011 | Kenmore Washing Machines
Model #26842691, Stock # 26842. It will go through the wash cycle, but it will not drain to go to the spin cycle or rinse cycle. It won't forward on. It just sits their.
heatman101
Jan 16, 2011 | Kenmore Washing Machines
I have a kenmore 90series the problem is that when it's done washing it want drain out all the water after two spin cycles
heatman101
Dec 27, 2010 | Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 22722 will not drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
sounds like you have a bad door switch
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
768 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
