Sorry, took us a while to have time to try the DVD, but now nothing will show on the television. The power comes on, but nothing on the screen and no sound. The screen is completely black, it seems like the back light is not even coming on now.Sorry, took us a while to have time to try the DVD, but now nothing will show on the television. The power comes on, but nothing on the screen and no sound. The screen is completely black, it seems like the back light is not even coming on now.
If I wanted to try replacing a part, is it worth my time or money, and if, as suggestion number 2 is correct and I need to replace the main board, what is correct name for that part?If I wanted to try replacing a part, is it worth my time or money, and if, as suggestion number 2 is correct and I need to replace the main board, what is correct name for that part?
I have replaced the main system board on thei television, and the power board, and still have the intermittant outages - the longer it is on , the more often it occurs until finally it won't work. Leave it off for a day, it works again.I have replaced the main system board on thei television, and the power board, and still have the intermittant outages - the longer it is on , the more often it occurs until finally it won't work. Leave it off for a day, it works again.
Time to consider getting the set to a shop---a service call is likely a waste of time. Look for a shop that does warranty work for this brand even if set is not in warranty as they will be better equipped to fix the set.Time to consider getting the set to a shop---a service call is likely a waste of time.
You can't post conmments that contain an email address.
I have a different Sony, but I think they all work the same. Go to menus (Press Home) Then select "Settings" and select "Screen Settings". Set Wide Mode to "full", Auto Wide to "off" , Auto Display Area to "off", Display Area to "normal". I hope this works for you
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Have replaced both boards, same issue.
