Question about HTC Cell Phones
My HTC mobile phone drains its battery too fast. I have to charge it every hour. This phone is brand new - only five days old.
    New Friend:
Turn the phone on and let it charge completelty. Then go and shut the phone off. Reboot the phone in CMV which is dos for phones. (you can do this bypushing a combination of buttons usually power, volume down and home check to see what yours is) go through the menus and look for Wipe Battery stats. IF YOU DO NOT SEE IT go back to the main menu and reboot phone. Wait for phone to fully charge again and shut it off. Now while it is off keep plugging the phone in till it says it is fully charged. Then unplug the phone wait ten-15 seconds and plug back in until it reads 100% when you plug your charger in
Posted on Apr 19, 2012
6ya staff
SOURCE:
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Apr 08, 2015 | Tracfone Wireless LG 440G
HTC Wildfire Battery is not charging fully
i am using an htc wildfire and it is not getting fully charged and when it reaches 30% the battery discharges even when the charger is connected. need help urgent
Jan 05, 2012 | HTC Wildfire Cell Phone
Last friday i bought the new HTC wildfire A3333 mobile nd put into charge for 8 hrs. The other day when i start to using one point of battery icon reduced nd on the same day i didnt nt use phone more. bt...
There could be 3 different things wrong:
1.) Battery is no good.
2.) Charger is no good.
3.) The port where you plug the charger into the phone is no good.
I would take it to your local mobile provider and ask them to test the phone, battery and charger. They will be able to tell you which one it is...battery and charger are pretty cheap fixes. If it is the port, you normally are better off getting a new phone.
Aug 22, 2011 | Cell Phones
Why its battery quickly drains
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
Charged battery fully fitted to phone discharged itself within hours changed battery same thing happens went back to factory settings same thing happens is there a fault on phone.cant get any satifaction...
HTC Phones are known for short battery life if you are using it only expect 2-4 hours
If you are not using it at all and have turned off wifi 3g the screen music and background apps and don't make any calls/txts expect as many as 18 hours.
Mar 11, 2011 | HTC Wildfire Cell Phone
Just bought a new Blackberry storm 9530 and it is not getting charged. Please help
Usually for brand new phones, the battery needs to be charged for two hours. But if you found out after it's been a while and it's not charging, make sure the battery is inserted correctly. If it's and the led is not on or no charge indicator, do the following, take out the battery, unplug the charger from the phone, press and hold the power button for five seconds. This drains out the battery. Now put the battery back in, plug the charger into the phone and let charge. Don't worry if it doesn't recognize it immediately. I hope this helps
Mar 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Feb 07, 2009 | Sony Ericsson W910i Cellular Phone
Fast battery drain only 6 hours standby (new battery)
i think some of the motorola mobile phones has a fast battery drain..
Feb 24, 2008 | Motorola Mobility E398 Cellular Phone
Cell Phones Logo
94 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
