Refrigerators Logo
Barry Alpert Posted on Apr 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint hss25gfp has a whistle
Hum or whistle while running
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Apr 20, 2012
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1158598
Points
10260
First case, whistling sound is what we call "Ghosting". To get rid of this sound one needs to put more gas into the system, but more gas will create the suction pipe to frost up and reducing the gas level will create less cooling. The best solution were to full regenerating Freon gas mean remove it filter it out and charge it back. However this will cost more $100 and basically you can leave it and live with it. No harm is created only the sound appears while running.
Second case were with a loud whistling, like a dying bird stuck in your freezer, you likely have a faulty freezer fan motor and you need to be replaced
Third case were with a lower pitched, sort of gentle whistling sound then you have an issue with the door damper, which allows the air flow from the freezer into the refrigerator. And assuming you don't have any cooling problems, it may simply be a normal occurrence, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Fourth case was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. We found out that the motherboard was probably defective.
Rather than go thru GE, you can found a new one online for 66 bucks. You can replaced it in about ten minutes and it's all fixed.
Fifth the evaporator fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evaporator fan motor. If this voltage drops out or fluctuates, it's more than likely the board need to be replaced.
Electrical diagram for hotpoint model # hss25gfp
The Hotpoint HSS25GFP is the same thing as the GE PSS25MSRSS Profile or Artica side by side and uses the same wiring diagram. Click=> HERE or click=HERE
I am here if you have questions, John Tripp Appliance 911
Contact me here.
Howling noise in HSS25GFP
I can only tell you of my experience when my freezer/Refrigerator made those similar sounds. I pulled it out from the wall and saw some dust accumilation so I took the bottom access panel off to the fan and compressor compartment. It had a lot of lint like dust accumilation so I cleaned it. I actually took my air compressor and blew it out.Made a little mess but nothing vacuum cleaner couldn't handle. Anyway it helped a heap. It's like any refrigerant device. The filter needs cleaning. Not sure it will help with your problem but it did mine.
2answers
Freezer fan makes loud humming sound
sounds like the bearing in the fan motor is gone. need to replace it.. ok
Hotpoint HSS25GFP freezer side keeps thawing completely and refreezing causing freezer burnt food. what would cause this
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Freezer humming
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
1helpful
Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
Hotpoint side by side refrige problem
Sounds like the gear jammed , replace the ice maker for a fix.
Maytag side by side
Sounds like a compressor problem. Unplug it and check the condenser for cleanliness. Clean if you see any dust build-up. Condenser may be located in back behind a removable panel. be sure to reinstall the panel when you are done. If the compressor is hot allow it to cool off and plug the refrigerator back in. If you get a hum and click from the compressor call for a service tech.
Fridge is making noise
The high pitched sound could be from the evap fan motor. If you can get to it a drop of silicon oil would solve the problem.
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
