SOURCE: I have a model 297980
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
SOURCE: My Proform XP Trainer 580 started to speed up
Dear Sir:
Thank you by your request, I hope everything is fine.
I will try to help you inmediately.
Connectthe test leads to the volt-ohmmeter. Plug the black test leads into the blackjack marked "Com" or "Common" on the front of the meter. Plugthe red test lead into the red jack marked "Volts/Ohms" on the frontof the meter.
Setthe meter's function switch to "Ohms" and the range switch to the"R x 1" scale. If your digital multimeter is an auto ranging meter,you will not have a range switch. Instead, you'll have just a function switchbecause the meter will automatically select the right range for the quantitythat you are measuring.
Turnoff the power and remove the fuse to be tested from the circuit. Never test afuse for continuity while it is still connected to the circuit that it is usedto protect. If the circuit still has voltage, the meter will be irreparablydamaged. If the fuse is still in the circuit when tested it is possible to geta false indication that the fuse is good if the meter gets a completed circuitthrough other circuit components. To be safe, always remove the fuse from thecircuit before testing it.
Touchthe black test probe to one end of the fuse and the red test probe to the otherend of the fuse. It does not matter which probe you touch to which end becausefuses are not polarized. You are checking to see if there is continuity throughthe fuse element. A reading of approximately 0.5 on a digital meter's LCDindicates a good fuse. Most digital meters read their own internal fusesresistance, hence 0.5 Ohms and not 0.00 Ohms. LCD readout of "O.L."indicates no continuity through the fuse. The fuse is bad and needs to bereplaced.
I hope that you can Handle the DVOM(Digital Voltimeter)
Thank you in advance, sincerely. Blessing.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
SOURCE: I have a proform xp
If you can walk on your treadmill but you get a burning smell from it, you have a bad problem and discontinue use immediately and unplug the treadmill. Burning smells are most commonly associated with the following problems: 1) Very high belt/deck friction. 2) Short in the motor. 3) Short in the wiring or electronics. 4) Literally cooking the lacquer or cardboard core (on cheap machines) in the motor from belt friction or a drive system obstruction. Friction is the #1 cause of this problem. Many cheaper treadmills have a motor with a cardboard core (people wonder why we are so down on cheap treadmills) and if the voltage and amperage through the motor heats it up sufficiently, it begins to smolder. If this is the case, you normally have to replace the belt and the motor and inspect the deck. If the armature has cooked enough in the motor, you also have to replace the motor. If the belt and deck check out OK, check for a short in the motor. You can run the motor with an independent power source like a fullycharged cordless drill battery to see if the symptoms are the same. Click on the following link for our motor test. If the belt and deck check out and the motor is OK, then check your wiring and electronics for signs of scorching and replace the appropriate part(s).
