I have tried every code that is on the web. How do I get the ability to play may Region A bluray discs on a Region B player? I know there has to be some kind of code to change it to read either A Region discs or all regions. Please get back to me with some kind of good news.
Did this to my philips BDP3200 blu-ray player and it plays region 1 dvd's, waiting on region 1 blu-ray to come to test blu-ray.
It still plays region 2 blu-rays after doing this.
Do this to change to it to region
0 so it can play any region.
1.Power on with no disc in tray
2.Press HOME
3.Enter 1389310
To check the current region
1.Power on with no disc inside
2.Press HOME
3.Enter 8520
Region 1 blu-ray arrived and worked no problem, so you can use this to make your player region free for both dvd and blu-ray. So your be able to play dvds and blu-rays from anywhere.
What bluray did you test it on? Some, though marked Region A, may be region free.
Does this also works for a philips BDP2900/F7 blu ray player?
Update: Can't change the Blu-ray region on it, only the DVD region.
I don't know if it will work with BDP2900/F7.
I don't have a BDP2900/F7 to try this on. 1.- Turn On Philips BDP2900 2.- Press the Home button on the remote. 3.- Press 1389310 on the remote. 4.- Press the power off on the front of the player. 5.- Power on using the front of the player. DVD will be region free but Blu-ray won't be changed. Since I can't test it, use at own risk.
SOURCE: Philips HTS7540 Bluray home theater. Region Lock
Hi
Most DVD Players these days are multi regional. The only variation to this are ones used soley for USA Market. Usually, in the insyruction manual it will tell you if your machine is multi rehion and if its default settin g is for one region, it will tell you if it can be reset.
Get back to me if you need any further help
SOURCE: Model:-BD-C6900 bluray + 3D (C-region)
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_bn67y5
SOURCE: I have a Panasonic DMP-BD80
Please follow the steps :
To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
SOURCE: since upgrading firmware on my lg bd370 bluray
It was just
informative news sharing and it's really helpful for everyone. Thanks for
that.
- <a
href="http://www.world-import.com/portable-dvd.htm">region free
dvd</a>
Dont have the dvd player in question : try this not sure if it'll work so come back and let me know
http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=DENON&Sub=Find+Hack&added=true&new
