Got the F2 code, cleaned the filter, still having a clicking noise in the motor area. Special access to the motor?
Any suggestions?
F2 if nothing in pump replace pump, propeller inside is bad. "less soap plz "
Pumps often creates problem. I can understand this problembecause 6 months ago my pump has creates same type problem but now it’s solvedcause of Toyo Pumps. Because I purchased New Pump from Toyo pumps (www [dot]toyopumps[dot]com/horizontal-dbh[dot]html).It’sEasy maintenance features easy to clean, easy removal by means of jackingscrews. Toyo Pumps has booster pumps, dewatering pumps, positive displacementpumps and submersible parts also available.
Thanks to Toyo Pumps,
John
http://www.toyopumps.com
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
So do you suggest replacing just the propeller first? Or the complete?
