Hii ppl i jus bought samsung tocco few days bak i was haviing same problem but i found out wot was wrong go in menu then select settings then phone settings then there is option on d bottom PC connections click on da select mass storage then save afta dat wen u connect ur cable to Pc it will install it self then ur ready to transfer into ur phone gud luck
Samsung software dont normally work on windows vista, so that mayb be the problem??
SOURCE: samsung tocco
You can't debrand your phone with Samsung PC Studio software! Try davinciteam.com.
Canny connect it like, the drivers wulnay install, ken?
and me
same :(
Same here!!
Hi, I'm having the same problem with my Tocco. It's a fab phone - probably one of, if not, my best. This memory card files transferring problem (i.e. drag n dropping files onto the memory card) is a bit annoying, but other that every other PC suite feature works fine on my Windows Vista. I wonder if Samsung are aware of this? Has anyone contacted sumsung directly? (P.S. By the way, I have been using a 16gb Sandisk micro SDHC card and my phone accepts it fine - result!!)
