Whirlpool motor # 3-3358. Can they be replaced or must the motor be thrown away and replaced new?
Motors have sealed bearings which it is cheaper to replace the motor. If you are hearing sound like this it may be your Tub bearing or one of the tub roller bearings these are like roller skate wheels they lay at each side under the dryers tub so it rolls smoothly and not many dryers use rear bearings anymore so look into the rollers and new tub seals or tub holder. The motors rarely fail in the bearing department and if they do a new motor is required.Remember to rate my solution and give testimonial it is how i earn my achievements Thanks in advance.
SOURCE: Whirlpool Dryer not spinning.
Sounds like the motor is not getting to proper speed. As long as you check for things in the blower housing and bad idler and support bearings before buying a motor. It could be motor bearings or weak windings. Replacing the motor is not a simple task and involves removing the front and the blower. Make sure it is the motor as most places will not take returns for electrical components.
Eric
SOURCE: Whirlpool Dryer LEQ9558KQ1
If you can hear/see the motor running, but the drum does not spin, you probably have a broken or loose dryer belt. You can easily determine this by opening the top panel and looking at the belt. Just lift the lint sheet cover on the top of the dryer and and pull out the screen. With the cover still open, locate and remove the two screws. Once the screws are removed, the top panel will lift up. The belt should be seen wrapped around the drum. If the belt has broken or has slipped off the idler pulley, it may be fitting loosely around the drum, or lying on the cabinet bottom. If so, the following instructions explain how to access the interior and replace or reinstall the belt.
Replacing the dryer belt on this model dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. With the lint screen door open, remove the two screws and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you.
PS Appliancepartspros.com has some excellent exploded view diagrams of your dryer, along with parts listings that you cna use for reference as well.
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
