Question about Motorola Mobility Miniblue H9 Wireless Headset
Poor sound quality
As a quadiplegic who uses switches near my ears to help control a wheelchair I need a bluetooth earpiece with a small protusion to avoid pushing the earpiece out of my ear. Enter the H9 Minature - but the audio quality is poor. Is there a similar earpiece on the market with noise cancellation?
Bluetooth ear piece pairing
open bluetooth in your mobile
open for all/show to all
switch on earpiece
long press the bt button comes with earpiece
now search for any bt device in your phone once detected
add to your bt list
next time whenever wanted to connect
just switch on bt in mob n ep
and long press the ep bt button
Dec 26, 2013 | Motorola Cell Phones
Tip
Motorola H500 earpiece fix
I've read quite a few posts from people complaining about the H500's earpiece being too loose and it flopping when they turn their heads. Here is a fix. After wearing mine for two days I was aggravated enough to try and find a solution. I love the H500 and didnt want to give it up,but the dang thing WAS loose... so :
1. Take the earpiece off just as if you were going to make it as if you would use it on the opposite ear.
2. Notice the sharp bend at the top of earpiece.That is where we will make the adjustment.
3. Get a candle or have a friend to hold a lighter steadily for you
4. Run sharp bend of earpiece thru the flame (DO NOT HOLD OVER THE FLAME) paying attention to the plastic,when it takes on an oily smooth look it will be warm enough to GENTLY push the two ends towards each other to tighten the hook shape. Run the earpiece under cool water when desired shape is reached and make sure plastic is cool. reattach the earpiece and place on ear.
5. Shake head side to side and that baby "shouldn't" budge at all. if it does adjust a little more using the above steps.
I hope this helps as it was one of the biggest gripes out there.
on Feb 04, 2008 | Motorola Mobility Bluetooth Hands Free...
If there is a battery in the earpiece; is it safe? There is some controversy about the safety of holding a cell phone to one's ear for extended periods; that's why I wanted an ear piece.
Yes it is perfectly safe. The easiest way to identify whether a bluetooth set is malfunctioning or unsafe is - HEAT. Normally batteries which are about to die or devices malfunctioning will heat up quickly when you charge it.
So unless you dont feel abnormal heat.. they are perfectly safe. Try to remove the BT earpiece when not needed. Your ear canal needs natural air flow. Blocking it with a prolonged use of a BT device could heat up the ear canal. That's where the problem starts! :-)
Mar 05, 2011 | Southern Telecom Emerson Bluetooth Headset...
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Dec 08, 2010 | Plantronics CS70 Wireless Headset
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
I ahve a samsung eternity phone from at&t i am trying to get my bluetooth ear peice to work with this phone it is also a motorola.The previous owner of this phone has their information for their blue...
Most bluetooth headsets or earpieces need to be "paired" to the phone before the can be used this usually just means you need to put both devices into pairing mode search (scan) from the phone select your earpiece in the list and enter a security code to complete the initial connection (pair) after that the earpiece can just be turned on and off with normal use
Aug 24, 2017 | True Blue TB-50CR Bluetooth Headset
How to use the ear piece
hi there. you need to charge the bluetooth earpiece, then, when it is on, search for its bluetooth. if it doesnt show up, play some music, then go options and go on "play via bluetooth". and then search from there.
hope i helped!!!
Nov 12, 2009 | Samsung SGH-G600 Cellular Phone
Can you adjust the size of the earpiece?
no you can't just bought a samsung wep301 it does not fall off they only fit people with bigger ears I have small and skiiny ears
Feb 10, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Changing earpiece
•First take your  device and hold it vertical.
•Looking at the earpiece that ressembles somewhat Alladin lamp, it's tip is positioned either at past 20 (for right ear) or before 20 (for left ear).
•Depending if it's one side or the other, you should turn the earpiece clockwise to 30 or counterclockwise to 30. So the "tip of the lamp", which is the ear channel of the earpiece in fact, is indeed at 30 past the hour.
•Then pull it out with a round motion downward, assuming the upper part is the blue light.
You can then change the side of the ear wire and or the earpiece for a different size supplied by RIM when you bought the device. I don't know how/where to get new earpieces. They don't seem to sell them separately...which is rather frustrating considering the price they sell this device!
Sep 03, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
I have lost the ear wrap for my bluetooth earpiece
contact support at jasco products and request one. they do have them available. click here to contact them jasco support
Nov 03, 2007 | GE Bluetooth In-ear Headset Wireless...
Motorola Mobility Miniblue H9 Wireless Headset Logo
32 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
