My tv used to come in with 480 an 1080p channels. now the channels only come in on 480. Called comcast, they said I should be getting the hi def from their end. we recently moved is it a hook up problem or a reset issue?
SOURCE: Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
SOURCE: LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
SOURCE: I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
SOURCE: There is sound but no picture
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
SOURCE: My Westinghouse sk26h590d keeps switching
how can i get my westinghouse digital tv to work with a computer connection? it keeps saying i have an invalid format
