I have never scanned. How do I scan a picture to my email in order to send it to my sister?
SOURCE: Scanner does not scan clearly
Please reduce the size of the Resolution and check for the quality of the scan
SOURCE: i NEED TO LEARN HOW TO SCAN
hi if u have installed ur printer u will have SOLUTION CENTRE,,,,find it and go from there
cheers
SOURCE: wanting to scan from scanner to computer
this happened to me too. i don't know how to fix it on the printer, but i scanned it through the computer. i went into the hp solution center, went to the scanning section, and told the printer to scan it from the computer. it worked fine. that way you don't have to save it to a memory card or anything. they went to the same folder all my other scans go to.
SOURCE: white spots on scanned pictures. how to fix?
better change the glass of your scanner to avoid this problem in thw future and one more thing when ever you are not using the scanner put a soft cloth over glass and cover it or put a A4 size paper it will avoid dust and scratch try this
SOURCE: How do I scan and send the scan to someones email
I have a Laser Jet M2727NF myself and i cant tell you that this printer does not have the option to send an email directly from the printer without using a computer...
The closest thing would be to use the "Scan To" button on the printer, select your computer and hit "start scan"
This will scan the document and bring up your default email client, probably outlook, with the document already attached, then you will need to send the email normally
I don't remember getting any help. As a matter of fact I don't think anyone got back to me.
