I have a( hard disk adata classic ch91) has fallen on the floor now not working ! Is there a solution to fix it ?I have a( hard disk adata classic ch91)
You can't post conmments that contain an email address.
Use something similar to an ATM card and pry open the bottom face. There are no screws but the faces are glued pretty good so it will take some effort.
Once the face is off, its pretty simple. About 4 screws to free hdd from the shell and then disconnect from the data connector
I recommend SpinRite from grc.com. It is the most diligent utility I have used for this. Explore and understand the explanation of what it does on the website.
I am not sure what you mean by "performing in page". But as far as an error goes that's probably a sign of failing drive. You should back up anything on there as quickly as possible. Although it's possible that what your seeing is corrupted data on the disk and not necesarily failure. Could be a problem ocurred when data was being written.
the wiring is faulty (short circuit, open circuit ). the hard disk
drive is faulty. the main controller PCB is faultyE602-oooo is A mount
error was detected when the hard disk was started up from the boot ROM
0002 Adata read error ( from the boot ROM )
