First make sure on the machine that all adjustable legs under neath are touching the floor and it is level if all is good. THis could be a case that the weight that balances the machine inside is either loose or off this is a big steel weight or a concrete weight under neath the machine and behind its cover from the rear. This has to be opened up to see what it actually wrong. Please dont forget to rate my solution and leave testimonial this is how i earn my achievements . Thanks in advance
Maytag machines do not have a concrete weight at the bottom. I think you are thinking of GE. I carefully aligned the inner tub to the outer tub by measuring all the way around and that seemed to fix it. Thanks, Joe
