It is starting up fine but just stops after 2 mins, flashes LE. The clothes are very wet
This is caused by an error from the hall sensor on the motor. It is possible that one of the connectors has come loose (this is an issue with LG's or it could be the hall sensor it's self is bad. First check that the harness that connects to the motor is tight. If that doesn't help then the hall sensor will have to be replaced. The hall sensor is located on the motor. The hall sensor basically tells the computer which direction and what speed the drum is turning.
clothes still wet with 2 min. left
