Sportline 345 Electronic Pedometer Logo
A
Anonymous Posted on Apr 23, 2012
How do i set a 2007 sportline 4204 pedometer - Sportline 345 Electronic Pedometer
5 Related Answers
Anonymous
  • Posted on Mar 19, 2009
SOURCE: instructions for setting pedometer by sportline
Go to sportline.com.
click on your model and you can download instructions
Anonymous
  • Posted on Apr 02, 2009
SOURCE: reset distance mode in miles/not km
http://www.sportline.com/manuals/345.pdf
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
shannongreer
Shannon Greer
  • 75 Answers
  • Posted on Jun 02, 2009
SOURCE: how to reset electronic pedometer sdc sportline
Press the reset button and hold for a couple seconds.
shannongreer
Shannon Greer
  • 75 Answers
  • Posted on Jun 22, 2009
SOURCE: How do I change the battery in my 345 Sportline
the battery is under the front cover. Pop it open with your fingernail or a coin. It uses a CR2032 button cell battery.
Anonymous
  • 742 Answers
  • Posted on Sep 07, 2011
SOURCE: How do I set a 2007 Sportline Pedometer 4202
ask the pedometer search engine
How do u turn off 4204 pedometer
How do i turn off the sportline 4204 pedometer - Fixya
www.fixya.com/support/t12066026-turn_off_sportline_4204_pedometer
Mar 17, 2012 - 1 Answer. I got a SportLine FM Radio Pedometer and it does not have operating instructions with it. Can you help? Sep 07, 2010 ' Sportline ...
How to turn off 4204 pedometer - Fixya
www.fixya.com/support/t23625149-turn_off_4204_pedometer
Feb 22, 2014 - How to turn off 4204 pedometer - Pedometers question. ... It does not say in the manual how to shut it off. How exactly ... How do you turn it off?
How To Turn Off Sportline 4204 Pedometer - Askiver Docs
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
2answers
Need instructions for sportline 343 pedometer
Sportline has the manuals for many of their pedometers on their product page. For the Sportline 343, see: http://www.sportline.com/products/pedometers/343-talking-calorie-pedometer.html and click on the Product Manual tab. Then click the Download button. The direct link to the manual is http://www.sportline.com/manuals/WV3482BK.pdf .
If you need help with a specific issue with the pedometer, please let me know. I may be able to provide additional information.
2helpful
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
I have a blue sportline pedomer with the date of 2007 on the back. I have lost the instruction pamplet on how to set the pedometer
Go to Sportline Website and download the manual.
http://sportline.com/product.php?prod=15
I sure hope this helps!
Lori
2answers
Sportline Fitness Pedometer 360 Manuals
you can email sportline and they'll send it to you if it's not already on their website
2helpful
2answers
Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Top Sportline Sport & Outdoor - Others Experts
ZJ Limited
ZJ Limited
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
