Fan speed chain pull switch
Zing Ear ZE-208D seems to be a compatible replacement: https://www.ceilingfanswitch.com/product/zing-ear-ze-208d/
Pull Chain on Bottom
Santa E70469
SwitchCo part # 01
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
or
KensElectronics.com part # ZE-208D-01
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
SOURCE: how to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
SOURCE: The switch that controls my fan speed is in the
hi there,
that was a common problem on that fan, the chord chain was stuck on slot groove way to rotary switch inside you ceiling fan,the only way to
repair this to disconnect and pull out the ceiling fan and dismantle the housing whrere the control switch is located,
upon opening you can see the groove where chord chain was stuck released,possible if you can change the chord w/c is a smooth one so it will never stuck,then reassembly again and put it back, or you can change the control switch by modifying the circuit control and put it on your wall,but this is not easy job you can hire and certified technician to do this,have a good day.don't forget to rate me,thanks a lot.
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
