Washing Machines Logo
Posted on Mar 01, 2018
My lg washer wont turn on
I have a 2004 lg washer WM-0532HW . when i went to go use it yesterday it would not turn on. it would not do anything. i checked the plugs and the fuse box in my home everything is fine so its something with the washer its self. what could it be? does the washer have a fuse in it?
  • nellame98 Apr 25, 2012
    i was not home when it stopped working so i dont know what code it said. i did call lg and the tech told me to hold down the knob for 10 secs and then plug it back in and try it again. so i did that and when i did that smoke starting coming out of the what i believe is the filter assembly. the tech told me to unplug it and have it service. my question is if smoke was coming out of the filter assembly does that mean that is bad and needs replaced?
4 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 08, 2008
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Anonymous
  • 66 Answers
  • Posted on Jan 15, 2009
SOURCE: no power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Anonymous
  • Posted on Feb 21, 2010
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Anonymous
  • 43501 Answers
  • Posted on Nov 16, 2010
SOURCE: OE for LG WM-0532HW
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Lg front loader washer WM 0532HW doesn't spray water anymore
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Every time my washer gets to the spinning cycle it makes a screeching noise. Wondering if there was a solution.
Almost sure it's a sock inside the drummer.
Must call a technician.
And in the future, use a bag to socks ;)
OE for LG WM-0532HW
heatman101
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Too much soap?
if the washer is draining ok if not you will need to ck the drain pump. i hope you useing the he sope if not you need to switch to he sope . try to do the above . and get back with me thanks.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
