Re: My itouch wont startup on screen u wil see a usb arow...
This usually means you need to connect your iPod to your computer and open iTunes. You may need to restore the iPod to original settings in order to fix.
If your itouch reads "disabled connect to itunes" and shows the "locked" icon and your itunes will not even recognize the device and itunes says your itouch is locked and enter password, Here is what you do to restore your itouch: (you will lose all itouch contents but it is worth it as almost all say it is broken and worthless)
1. Turn off your itouch or ipod. Do not have charger / usb connected to ipod or itouch.
2. With device off, connect the charger end of the cable to the itouch / ipod but do not plug the usb into the computer.
3. Open Itunes
3. While holding down the menu button (and I mean keep holding it down), plug the usb into the computer.
4. Wait to see the new wonderful graphic on your device and computer screen that shows that your ipod / itouch is recognized.
Your itouch will start immediately restoring itself and you are ready to fill it up with wonderful images, photos and videos again!
So happy to share this tip. It saved me money and time.
Okay well you have to do a full restore. Turn your itouch completely off. With it off, hold down the circle button and plug in the USB cable connected to your computer. The itouch will power on and you will see the apple, but keep holding in the circle button. After 15-30 seconds, you will see another (different) cable/itunes screen on the iphone. iTunes should then recognize that the itouch is in recovery mode and you can then do a restore. You should be good from there.
Remember, turn off the itouch. Then while its off hold down the circle button and plug it in. Keep holding down the button until the recovery screen comes up. Good luck!!
Now
frist of all check if there is a new update for itunes and if there is download it and install it that might solve ur problem but if it doesnt let me know.
make sure you're USB is unplugged. when you're at the screen with the itunes symbol and the usb arrow, hold down the home and sleep button until the screen goes black, at this point, keep holding for another 10 seconds. at this point your screen should look black as if the ipod is off. connect to the computer and itunes shoulds show a message like "itunes has just discovered an ipod in recovery mode" you'll be able to do a restore and regain use of your touch.
if this does not work, message me back.
