I have the zigzag stitch set on my Bernina 1130 so I can do applique work. I have the Stitch Width set to 1.5-2.0 and the Length set to .25 -.5 (.5 resulting in stitches that are actually too open for applique borders). After sewing an inch or two, the stiches clog up as if the length was set to 0. I have cleaned the feed dogs, turned the machine off and back on, still no good results. What can I try now?
For the best satin stitch, use a sharp (jeans or microtex) size 70 needle with a 50/2 thread. The best foot for your machine is a #20. It is open in the front for visibility and hollowed out underneath to allow the bead of stitching to flow evenly. Do a sample to determine stitch length. Also, a light weight tear away stabilizer will be helpful.
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
SOURCE: My old Bernina 1130 has never given me trouble,
If you have a drop feed mechanism make sure you have not dropped the teeth down by mistake, make sure you have enough pressure on the foot, remember you should not be able to pull the fabric through by hand if the teeth are up
I have solved this problem with changing the needle (I didn't realize I had a JEANS needle in, and should have had a "90" or so, with a bigger eye. Also, someone else told me that the bobbin thread should be slightly smaller than the main thread-for instance, top thread 50 wt, bobbin thread 60 wt.) AND I will be purchasing an applique foot for the clear bottom which will make it easier to see what I'm sewing!Thanks to all who sent in suggestions.
