White line goes away after 20 minutes but now makes shadows on people were white line was
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
SOURCE: red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
SOURCE: shadows on lcd
Why does my lcd proton Television have a long black streak on the right side of the screen?
SOURCE: I have a 52in lcd tv and when you turn it on they
I would check the LVDS cable from the main board to the t-con board and the ribbon cable from the t-con board to the LCD display for good connection. Be very careful not to damage any of these. Sometimes they become corroded.
