When sawing the blade falls out
SOURCE: Blade falls out.
the lever for the lock has a indentation in it to lock the blade in place (at 90 or 180 degrees try both) make sure it drops into same in blade. not all brand blades will fit even with the word universal! good luck
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
SOURCE: clamping a blade in the saw
it's either a cylinder behind fence,twist it to open,let go so it close's. or there is a lever on the side that you lift up to insert blade let down to hold in place
