SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
SOURCE: mtd rear tine tiller model
Go here and enter 214-410 and your s/n. There is a part manual that should help you.
SOURCE: I have a MTD yard machine rear tine tiller. Goes
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
SOURCE: Have a MTD Yard Machine rear tine tiller Model 410
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_d71920e629f739cb
I.m afraid that the cable adjustment is just fine, I needed to back it off quite a bit after replacing the badly worn belt, but it engaged, and dis-engaged just fine. As far as I can see, the only thing that could be wrong, is some kind of problem with the shaft that has the detents. It would be wonderful if someone with more knowledge than me would be able to confirm that.
