SOURCE: panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp, can you ck voltage to ballast should be around 300 volts
SOURCE: Can't power up
The buzzing noise you are hearing is most likely the ballast fire, this is good. You most likely have a bad lamp which is the best case for you. I would recommend pulling the lamp out and looking at it to see if its physically shattered or not.
The instructions for pulling the lamp can be found in your owners manual. If you do not have this anymore just look on the sides or the back of the tv for a small door with a screw or 2 in it. take those screws out and the door should come off, then take the screw(s) out of the lamp and pull it out. if you see glass rolling around inside you will need a new lamp. Let me know and I will help you find a good one at a good price.
Tim Nolan
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
