Question about RCA RTD317W Theater System
I have a RCA RTB10223 model, and my problem is I can get the surround sounds to work with a movie in, but its not working with the regular TV. What do I to get it to work?
  • 760 Answers
That is because your movie is in 5.1 surround or better. Over the air and cable broadcasts are not always broudcasted with surround sound, there fore you will not always get it.
Posted on Apr 27, 2012
    New Friend:
  • 3 Answers
I had to go buy an optical cable to use between my LCD LG TV and this system to get the sound to work. This system is not ARC compatible through the HDMI cable. I only found this out after several hours of frustration. Simple fix... Optical cable at my local department store for $14.99! Hope this helps! :) I find that for the price, this system sounds great!
Posted on Jan 14, 2013
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I have a new 52"
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Posted on Feb 28, 2009
Anonymous
  • 13 Answers
SOURCE: DVD problems
u having a problem with your tv . take it to a professional.
Posted on Aug 29, 2008
rad921
  • 132 Answers
SOURCE: RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Posted on Oct 17, 2009
canwoodjc
Canwoodjc
  • 3301 Answers
SOURCE: I have an RCA surrond
you can't unless the station is broadcasting the selection in surround sound,
Posted on Sep 10, 2011
Panasonic Model TH-50PH10UKA. Hooked up to surround sound and works well. When I connect to a second input do not get any sound, how do I turn TV speakers on or Off.
Found in menu setting of tv.are you using RCA or hdmi or optical output as these need to be set in mode setting on soundboard and tv menu settings.
Jan 03, 2015 | Panasonic Televison & Video
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
How too hook surround system to regular tv. Example : a football game. Thanks
Well, since the "regularTV" has no make or model number I will have to guess what outputs it has to suit your surround sound system which also has no make or model number! Using outputs that show left and right speaker channels wire each to the left and right speaker channels of the surround sound amplifier. How many, I don't know!
Jan 23, 2013 | Audio Players & Recorders
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
I just bought a Emerson 32'' LCD TV Model # LC320EMXF and a RCA Surround System Model # RTD315W. I also purchased a HDMI cable to connect them. The TV works and the Surround System works but I cannot get...
The TV may not have an audio out feature. I just run the tuner sound (i.e. my cable box) directly through the srround sound for the TV audio.
Nov 28, 2009 | Cell Phones
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Jun 24, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Feb 02, 2008 | Pioneer HTS-GS1 Theater System
DVD problems
Nov 06, 2007 | RCA RT2600 System
RCA RTD317W Theater System Logo
962 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
