First the printer was printing very slow. Now when I plug it in it comes on automatically. The cartridges move a bit then the On/resume light stays on, the Check Paper and Check Printer Cartridge blinks, and there is an E in the Copy area. When I open the door the ink cartridges will not move to the center and I cannot turn it off without unplugging it.
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
SOURCE: HP C3100 Printer, changed black
I did not get problem fixed by your expert, he did not know C3100 printer and how to fix the problem,
I had check all areas of the printer for screws he said to undo and there NO screws then the session ended and I did not get the answer. Please do not charge my American Express for a none solution and a person who did not know my printer.
SOURCE: blinking check print cartridge light and "E" for copies
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Testimonial: "Thank you for this information. I am, in fact, using a genuine HP ink refill, but have come to the conclusion that it must be empty! Who knows?"
If you need more help come back.Post /
thumbs / testimonial are
welcome!
